cheers, do you have a rad at the top
of your Case sgt?
Heh, for me your better to have it commoned up as you've then got all your cooling capacity available to either the CPU or the GPU or both at the same time. As you say as long as the pump is upto the job (and an 18W DDC definitely will be if you have one).
