It's hard and it would be long to explain all this, but one of the cards, clearly is not 100%...
Despite the fact the CrossFireX won't function and I always had some weird problems with drivers etc.
The card has an LED and it should be on if the card's ON. I won't go into details, but the rest of the hardware is fine, one of my 7990s is causing that my PC freezes during booting up, and it happens at any stage, randomly.
For example, right now, Windows is running, one of the cards is "ON" and the other one is not. The device manager shows three 7990s, one of which is 'disabled'. I enabled the third 7990, the screen went black and came back on. The device manager shows three 7990 enabled. However one of the cards (LED) is still off.
PC rebooting.
The PC froze with BIOS boot logo... I can only reset it.
It's booting up again and it's on. One LED is on and one LED is off. There's three 7990s visible in the device manager.
That's what happened just now. The situartion will be different tomorrow. The PC will freeze when the windows logo is pulsing during booting up.
Sometimes I get USB devices being unrecognised errors, or some weird drivers are being installed. It happens after I had to reset the PC.
Is there anything I can do? VBIOS flash or something?
I only have 6 days of warranty left though... (Apparently I have one more year if warranty left)
edit: after another reboot, there's now four 7990s visible in the device manager, one of which is disabled. I'm going to enable it now. It's possible that I get 0xB3 BSOD error. This time the device cannot start, and there's a problem. When I scanned for a new hardware the problematic 7990 disappeared from the list and there's only three 7990s left in the device manager.
Obviously there's a problem. I contacted OcUK and Sapphire already.
PC rebooting.
