- 21 Feb 2003
- Southampton
Houston, I have a problem .......
If I install either a Opty 170 or a 4800+ on to my Asus A8N32 Sli moby, and then check within device manager, it only lists one core instead of two under processors. There used to be two listed, but no matter what CPU I try, when I reboot, I can't get device manager to show both cores.
also
If I check the temps, using the program coretemp, it only shows one temp, instead of the two core temps that it used to.
I have checked both chips out on another system, and they both came up with two cores within device manager. (Thus, both the OPTY and the 4800 are intact when it comes to their dual cores)
I have the most up to date bios and drivers, and have cleared the CMOS, but although it lists the chip on the post screen, the PC is definately only seeing it as a single core CPU, by the time it reaches to the desktop.
Anyone got any ideas, then I'd be more than pleased to hear them.
Cheers in advance.
also
Cheers in advance.
