One of my first :)
19 Dec 2006
UK
Had an old system that somebody wanted the drive destroyed in, thought I'd grab a quick picture before I did the deed...
One of my first shots with my Fuji S9600.
Nice photo Dano, i really like the lighting in it. the Fuji S9600 isn't a DSLR is it?
Great idea but the lamp shade reflection detracts from it IMO. If you changed the lighting slightly, something with less of a reflection I reckon this could make an awesome shot.
Also, try to play with the white balance for some interesting effects. Drop the temperature right down for a blue tint, it will look good with that too.
You're right, makes it look more 'mechanical'/colder...
I'd prefer the first shot, without the lamp, same angle but keep the same lighting / colours. The last one doesn't look or feel right in the way it looks, the dust and positioning doesn't make it as pleasing to look at.
[IMGhttp://img403.imageshack.us/img403/7595/hd1bluecopyqe4.jpg[/IMG]
Yeah, try an even stronger blue tint and an increase in contrast, I reckon it would look well. Something like this:
In all honesty I didn't take much notice of the lighting atthe time, that part of the workshop is only lit by that one old lamp and I just threw the drive under it to cast some light on the subject but certainly if I was attempting to re-do the shot I would go for something far less obvious, not to mention at the very least removing the clip on lamp with the dead bulb from the picture :)
I did nothing to the picture other than auto-levels which only adjusted things in a very minor way, I'll play with some editing later on :)
i like no.1,i took some a couple of years back, exactly how scuzi is explaining, if you don't mind, i'll post a couple to show you :)
I think all thwe shots you posted look great, it's a really interesting and different thing to photograph, and the lighting on them looks great as well.
I think my favourite one is probably the first one, looks almost like a catalog picture. I think the only thing I might try to do would be to get rid of the reflection of your lamp shade ;)
