One of those "spec me" threads
10 Jun 2006
Wigan
Hi,
My pc is getting old now and there are a few games I can't play on reasonable settings any more so I am looking to upgrade,
I am currently using :-
CPU, AMD Phenom II X4 955
MOBO, MSI 870A-G54
RAM, 2X4GB Corsair pc10700
GPU, AMD Radeon 6950
PSU, Corsair HX 520W
SSD, Corsair Force3 240GB
HDD, 2TB Samsung F1
Everything else such as OS, optical drives, monitors, input devices etc I want to keep as they are all quite new,
Ideally I would like to reuse anything from my old build eg.(SSD, HDD) but I will replace if it's worth it.
I have no preference between manufacturers, I will go with whichever offers the most value.
Thanks in advance for your help.
*edit* forgot to mention, I would like to stay within around £600
Yo, what case are you using?
I see that the board you have has an IDE port on it, are any of your optical drives IDE?
Howdy, Thanks for the reply,
It's not the best case, a cheap coolermaster ATX thing I got a while back, can't find the model anywhere.
As for the IDE port, I have never used it, I have all sata drives.
Thanks
My basket at Overclockers UK:
Total: £591.21
(includes shipping: £12.30)
Re use your RAM.
The card will fit if you take the middle HDD cage out, leaving 3 x 3.5" bays and 5.25" in the top.
New PSU as the HX520 is x amount of years old.
