One phone number with 2 sims?
8 Jun 2006
Hertfordshire
Hi All
I have asked a number of providers but wants to check, this used to be possible via T-Mobile but no one including T-Mobile offer this any more
Is this the case? Though I would as I group I trust as well
Thanks
Mart
Orange used to do this on business contracts but i havn't worked there in a while to know if it's still selling it. You can achieve a similar thing with SIP for what it's worth.
Orange do (did do, I cancelled mine) a dual sim thing. They were different numbers but they forwarded to each other. Both on the same bill / account.
Hi there,
Not exactly dual sim but O2 has just released an app called "tu go" for its pay monthly customers which essentially means you can use two to five phones with the same phone number so long as you have a data connection. It even allows you to turn your PC/Tablets into a phone (its only available on IOS, Android and windows PC atm, but they are eventually going to release versions for windows phone and blackberry).
You just download it onto your device and it allows you to use your Contract minutes and texts and works exactly as if you were making a call or text from the primary device and even shows up with your phone number at the receiving end (the receiving end does not have to have the app installed unlike skype whatsapp etc). Also if someone calls/texts you all the devices tied to the account will light up at the same time and you can answer any one of them so you dont have to set a preferential one or anything.
Gizmodo actually did a review of it today which goes more in depth so have yourself a read :)
http://www.gizmodo.co.uk/2013/03/o2s-tu-go-app/
And heres the links to download.
IOS:
https://itunes.apple.com/gb/app/tu-go-from-o2/id568007896?mt=8
Android:
https://play.google.com/store/apps/details?id=es.tid.gconnect
Hope this helps.
