rpstewart said:I could go on but it shows that neither is perfect, you have to pick the one which has the best match of features and price.
iraiguana said:The quality of the sensor is also a factor, although it will have less pixels, they will be of higher quality and so can yield better colour reproduction. Also a major factor is the lens that you are using your camera with.
Combat squirrel said:TBH mate I think the 350D and the 30D have exactly the same sensor, 8mp Canon CMOS, I don't see them developing the same size sensor twice
Dpreview said:Eight megapixel CMOS sensor (not same as EOS 20D)
BTW: The 30D and 350D do NOT have the same sensor. The 350D sensor is a 8mp sensor; smaller than the 30D.
