one sql script for mssql 2000 and mssql 2005 (or later)
Man of Honour
18 Oct 2002
Northallerton/Harrogate
Is it possible to write a sql script that'll run some sql for 2000 if it's installed, or some other sql for 2005 or something else if version 7.. or something's installed - e.g. do nothing?
I can get the server version with @@VERSION, I think.
I can't seem to make it work in an if/else bit o' code.
What it's for:
For 2000 I'd do
--create some users:
EXEC sp_addlogin ...
but for 2005 I'd want to do :
create login ...
create login ...
At the moment I have 2 scripts - with only that bit different. - Can it be put into the same script so users only have to run one, without thinking (or knowing) which version of sql server they have installed?
Think i'll go for this sort of approach
PHP:
IF CAST(SERVERPROPERTY('ProductVersion') AS VARCHAR(10)) LIKE '8.%'
	PRINT ' SQL Server 2000'
ELSE IF CAST(SERVERPROPERTY('ProductVersion') AS VARCHAR(10)) LIKE '9.%'
	PRINT ' SQL Server 2005'
ELSE IF CAST(SERVERPROPERTY('ProductVersion') AS VARCHAR(10)) LIKE '10.%'
	PRINT ' SQL Server 2008'
or
PHP:
if @@version like '%Server 2005%'
begin
 exec
end
else
begin
 create
end
type thing
OH well it doesn't work :)
edit, yes it does.
One too many GO statements.
