Is it possible to use one UPS to protect two PC's from surge/spikes and power failures? What rating UPS should I get for these two machines? (will be on at the same time)
3700+ stock, 1GB RAM, 2 x 7200RPM HD, ATI X300, M-Audio soundcard, 2x 12cm case fans, CPU fan, DVD-RW. According to PSU calculator 260W. Round up to 300W
4400+ @ 2.7ghz, 2GB RAM, 3 x 7200RPM HD, ATI X1900, 5x 12cm, 1x 8cm fan, 1 DVD-RW, 1 DVD-ROM. According to PS calculator 470W. Round up to 520W
I estimate 1500VA should be suitable. How would you connect up two PC's to the UPS controller port (USB and serial, can you use both at the same time? Looking at the APC Smart-UPS 1500VA USB & Serial 230V
http://www.apc.com/resource/include/techspec_index.cfm?base_sku=SUA1500I&total_watts=50
"Audible noise at 1 meter from surface of unit"
Does it have a fan?
Or I could just buy two UPS's, £65 CS-500 for the HTPC, and a 1000VA for the desktop
Does it have a fan?
