One USB-C device over two machines
10 Jan 2009
Hi all,
I'd like to be able to use a USB-C audio interface on both my desktop and work laptop (via a docking station) without having to manually change the cable each time - is there a solution? I guess I could use a USB switch/splitter of some kind but I'm wondering if in this day and age there is a more elegant solution?
Cheers!
Unless the device is designed to be connected to two hosts at once, then no, there is no more elegant solution I'm aware of, a USB switch is your best option AFAIK.
I have a similar setup, my iFi Zen DAC only has one USB input. A simple KVM USB switch is what I use - there's a simple button to press to toggle input, it works well.
I see, thanks. I'll see what devices I can find!
Ah right thanks! Do they make usb-c KVM's? it seems a shame to have to use a load of converters
Looks like it, but they seem oddly expensive vs USB A KVMs. Likely because they support higher data rates (which you won't need with a DAC).
No need for converters though, you can just use USB C to A cables
