Hi, I have OneDrive installed on Windows 11 and it normally boots at start up as this is where all my files are saved as default. I noticed that it didn't load earlier on so I opened it up manually and checked the settings but the OneDrive app was recently updated and there's nowhere which says 'enable at startup' like it used to. I noticed there was no log in startup apps either. On my other laptop there is a log in startup for it. What I did was unlink the laptop and then re-link and everything is fine since, there is a toggle in start apps and it now loads on boot. Do I need to worry? Unsure as to what happened. What does unlinking actually do as my files remained, but it seemed like they weren't online versions? Cheers.
