Onedrive stuck syncing
24 Feb 2004
St.Andrews
Hey,
Had a quick search and can't see anything immediatly obvious but I'm having trouble with OneDrive and it getting 'stuck' syncing is the best way I can describe it!
It sits there doing that day and night and never syncs the latest files in the folder no matter which way I view them (via PC or my Lumia 930) and as far as I can tell this only happened when I installed Windows 10!
I've tried all the troubleshooting on Microsofts website but not got anywhere with any of that either!
Anyone have this problem too or know of a workaround? My Googlefu is weak :(
Hey,
I had something similar to this with, in the end it was a file with a name too long... I had to remove everything then re-sync without that file and it when through ok.
Maybe try syncing just a few files at a time?
