- 18 May 2010
Hi,
I've been experiencing some very odd behavior with my OnePlus Nord which is a couple of weeks under a year old originally purchased from John Lewis (I'm mentioning this because I think they supply support for the full 12 months?)
For the first 9 months the phone would Warp Charge, first time every time, it was great it would get plenty of charge in by the time I had a shower for example.
Then suddenly a month or two ago it started to Warp charge less reliably, it would take a few attempts of unplugging and plugging back in for it to finally warp charge. I cleaned the port but still the problem persisted. In the last couple of weeks Warp charging has stopped completely, it will not Warp charge at all so I've resorted to charging overnight, first world problems.
Yesterday the phone refused to charge, I plug it in, it says its charging but the percentage never increases, left it overnight and charged 1% all night.
I try again this morning and for some reason its started charging although very slowly, 10% in an hour.
This is with the OEM charger and a third party charger and two OEM cables one of which is new, I've restarted it, powered off and on, tried switching off Battery Optimization but nothing works. The only thing I haven't done is do a full reset which I might do today but I have my Authenticator App on there which I need for work so being without this app is going to be a problem.
I only have well known apps on there, I don't install any spurious stuff especially not battery management or anything like that, the phone is fully up to date.
I've always had Nokia phones before and never had any issues so this is a bit annoying and really putting me off buying another OnePlus phone in the future. Has anyone had a similar issue and resolved it?
Thanks
Thanks
I guess as you say, if the full reset doesn't change anything, then it sounds hardware related
