I have a strange problem with my PC that has been going on for a while ... randomly the PC will freeze and a red line will appear at the top of the screen. There is no option but to hard-reset the PC
. No errors appear in the event viewer and this problem occurs completely randomly.
I thought at first that it was a problem with the graphics card, so I repaced the X800GTO with a X1900XT - same problem remained. I have now replaced the mobo (Sapphire Pure Innovation) with a DFI Ultra-D and done a fresh XP Pro install. I still have the problem
! With the old mobo, sometimes when you turned the PC on after a crash, it would display a green screen of death (GSOD?!?) with an irql_not_less_or_equal message - with the new one, I'm sometimes getting it during normal operation as a normal BSOD, as well as the GSOD. I always thought this error to be RAM / mobo releated, but I know both to be fine. Stress testing and doing F@H, there is no instability and memtest runs fine on the RAM.
Does anybody have any ideas - I'm losing my mind here! Could this possibly be the CPU? All components are running at stock and temps are great.
// EDIT // I have .dmp files from the irql errors that windows creates - can anyone analyse these?
Forgot to say as well ... X2 3800+, X1900XT, 2G Corsair XMS Cl2 RAM, DFI Ultra-D, Hiper 580-R.
. No errors appear in the event viewer and this problem occurs completely randomly.I thought at first that it was a problem with the graphics card, so I repaced the X800GTO with a X1900XT - same problem remained. I have now replaced the mobo (Sapphire Pure Innovation) with a DFI Ultra-D and done a fresh XP Pro install. I still have the problem
! With the old mobo, sometimes when you turned the PC on after a crash, it would display a green screen of death (GSOD?!?) with an irql_not_less_or_equal message - with the new one, I'm sometimes getting it during normal operation as a normal BSOD, as well as the GSOD. I always thought this error to be RAM / mobo releated, but I know both to be fine. Stress testing and doing F@H, there is no instability and memtest runs fine on the RAM.Does anybody have any ideas - I'm losing my mind here! Could this possibly be the CPU? All components are running at stock and temps are great.
