I've had these ongoing system issues since I first purchased this PC.
logonui.exe errors
Whea_Uncorrectable errors
Low Memory error
Here's a log of the issues I've been having today.
The driver \Driver\WUDFRd failed to load for the device ACPI\PNP0A0A\2&daba3ff&2.
The maximum file size for session "ReadyBoot" has been reached. As a result, events might be lost (not logged) to file "C:\WINDOWS\Prefetch\ReadyBoot\ReadyBoot.etl". The maximum files size is currently set to 20971520 bytes.
Session "ReadyBoot" stopped due to the following error: 0xC0000188
The Open Procedure for service "BITS" in DLL "C:\Windows\System32\bitsperf.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
The Open Procedure for service "ESENT" in DLL "C:\WINDOWS\system32\esentprf.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
The Open Procedure for service "Lsa" in DLL "C:\Windows\System32\Secur32.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
The Open Procedure for service "MSDTC" in DLL "C:\WINDOWS\system32\msdtcuiu.DLL" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
Unable to open the Server service performance object. The first four bytes (DWORD) of the Data section contains the status code.
The Open Procedure for service "WmiApRpl" in DLL "C:\WINDOWS\system32\wbem\wmiaprpl.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
Reset to device, \Device\RaidPort0, was issued.
The DSM service was delayed by 12 seconds for a driver query/download/install on device 'STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT13'
The previous system shutdown at 19:23:52 on 19/01/2015 was unexpected.
Volume C: (\Device\HarddiskVolume10) needs to be taken offline to perform a Full Chkdsk. Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME <drive
" locally or remotely via PowerShell.
A corruption was discovered in the file system structure on volume C:.
The exact nature of the corruption is unknown. The file system structures need to be scanned and fixed offline.
Crash dump initialization failed!
The server {4AA0A5C4-1B9B-4F2E-99D7-99C6AEC83474} did not register with DCOM within the required timeout.
just ran a sfc /scannow and it reported nothing
How do I fix these annoying errors? I've had my ram replaced. I've even sent in the pc for repair but I keep getting these errors. memory error I get when I spend a certain amount of time in IMVU shop. I got this whea uncontrollable error again today when I was in the shop again. My friend thinks that my CPU might be the culprit. But idk what to think. I pay for a PC and I expect it to work. Not to be broken from date of purchase. Can someone please help me resolve these issues??
logonui.exe errors
Low Memory error
" locally or remotely via PowerShell.A corruption was discovered in the file system structure on volume C:.
" locally or remotely via PowerShell.Crash dump initialization failed!
