- 24 Sep 2005
- Middlesbrough
Hi guys.
A couple of weeks ago I bought said reciever in a complete package along with 5.1 speakers. (HT-S3305)
Now i've just noticed that the front right and front left speakers don't work.
On the amp there is the option of switching speakers from A or B or both or neither. I assume this was to switch between the choice of having larger front right and left speakers (which there is a socket for on the back of the amp) or the smaller ones which i'm using. Everything is wired up correctly using the correct colour coded wires into the correct sockets (clamps or whatever you call them!)
So if I were to select B on the amp then the front R&L speakers work but none of the others do nor the sub. If I have B disconnected then only the centre speaker, sub and rear speakers work.
I've tinkered with all the settings I can find and can't seem to solve the issue.
Does anyone have any ideas?
Thanks.
Edit: This is the back of the reciever. http://www.techdigest.tv/Onkyo HT-S3305 back.jpg
Also just noticed that they are labelled A and B. But when I select B, I can only have the sound in naff stereo and not complete surround sound
Thanks.
