Onkyo setup advice
16 Mar 2004
Oxford
I've just made some changes to my AV setup and decided I should re-calibrate my AV amp (Onkyo TX-SR875). However despite searching I can't find the setup mic. After searching online I can't even find a model number for the mic, and the instruction manual is very vague, would any one off eBay work?
if it used the hockey puck style then the model number is MIC-5000. If it's the tower style then its MIC-70001. I believe the 875 switched from one to the other at some point - best to try and source the same model yours shipped with.
Thanks, that means mine came with the MIC-5000, still can't find one in this country though. I'll set it up manually for now, and keep looking, both at home and on the internet...
