Online Animation
7 Feb 2004
Can someone recommend me a piece of software to do the following.
I make a product that I want to demonstrate the physical dimensions on a website.
I want it so they see a simple line drawing of an object similair to a brick, it then zooms in a bit and spins a bit, stops and shows the measurements then splits into equal pieces.
Cheers
Cheers
Your best bet would be to use Flash. However if this is too expensive could you not use an animated Giff?
