Online backup & Remote Access Solution?
18 Jan 2004
Somewhere
We are currently having some issues with some sales users over in the US. They managed to get their kit stolen and we have struggled to get them all working again (took 2 weeks).
Anyhow, were looking for a software package(s) will which do the following:-
Remote Access - We like logmein functionality but the problem is that the user can easily turn it off / mess with the settings or even change the account its attached to. Could do with something we can install which has the same logmein functionality (i.e. remote access anywhere with no VPN) and which is silent on the PC and can avoid having its settings messed with.
Backup - Were after something which will work in a completely automated fashion to backup the client PC to a cloud based service. It must be intelligent etc, and only backup changed files once a full backup is done. Something like Mozy maybe, but more corporate. Also would be good for the admin to be able to see what files are backed up and be able to retreive them from the cloud.
Be awesome if there is a single package which does both!
Any ideas? what do you guys use for managing laptops which basically you will never see, and which never physically come onto your LAN (they do VPN etc)
Crashplan for backup - you can have it back up to a local machine, remote machine - or for so much a month, their cloud services
Check out echogent (EchoVNC) for remote access. It can quite easily be locked down so there isn't even a tray icon
I use both quite successfully (used EchoVNC for a long time hosting my own "echoserver")
