Only 1 fan working
25 Sep 2007
Hertfordshire
I have a Gainward Ati 4870 512mb.
I don't no how long ive had this problem but only 1 fan is spinning.
Getting a bit worried as i hope i haven't damaged the card.
Does anyone have any ideas.
Thanks
No mine definately has 2 fans, and it's definately a 4870
Must be a special model :P
could look around the card and see if you can see the fan wire, check if its plugged in correctly.
guess you could get a replacement if its snug in, or you dont feel confident enough to start messing with it.
