Only 64-bit IE7 works
21 Oct 2002
Wellington, NZ
Hi all,
Got a problem with IE7 and MSN. Only 64-bit IE7 works (32-bit doesn't) and I cannot sign into Live messenger, it says there's a problem with DNS and Key ports:confused:
Any ideas? I'm on Vista Ultimate 64-bit
Had the same problem a while ago. No application that used the internet worked, except 64 explorer. Never found a solution and ended up reinstalling vista.
Right tried uninstalling NOD32 and it now works fine. Is there an update due to fix this? I'm now on the net with no AV :\
Sorry I been away from pc, yeah its an issue with Nod32, uninstalling and reinstalling is only thing that fixes it. I was using version 2.7 something at the time. Now using version 3 and its not happened since. HTH.
Edit: With version 3+ make sure you get the 64 bit version.
Edit 2: http://www.eset.com/download/home-64bit.php
