only connected locally wireless vista64 and belkin
31 Aug 2003
im running vista64 with a belkin g pci wireless card.
every 24 hours the connection will say 'local connection only' meaning i am connected to the router (be speedtouch) but not the internet. i have to disconnect and then reconnect and then everything is fine. i have tried updating the drivers but once i did this manually it would drop and i had to disable and then reenable the belkin for it to connect. having vista detect the best drivers means i just need to disconnect and reconnect.
any idea what could be causing this?
hi dozer, take a look at my thread in "be box or my be line" it sounds like ** having similar problems as myself and i'm on vista64 aswell although i don't have a belkin wireless card i do get the exact same problems.
i'm going to order the netgear834GT come payday next week
from what i understand its the crap drivers from belkin, i have the 802.11g f5d7000uk version and i think the drivers are crap.
my housemate connects fine on his on xp so not the router.
