According to that review I posted earlier, I think you could try using high instead of extreme settings, and make sure you are not using SSAA but only normal AA. That should give you some performance boost, while graphic quality wise probably won't drop much to the point of making you really noticing it. If your eyes can't really tell too much of difference between extreme and high graphic quality, you might as well run the game on high if it would give you much more consistent frame rate.Thanks for the replies guys. It appears to be the game, as I overclocked my gpu and saw no fps improvement (cpu still at 70%). On the bright side, game runs smooth enough and is playable![]()
You got a 120Hz monitor?isnt sleeping dogs locked at 60fps anyway??? i dont get above 60fps, it really bugs the titties off me when they lock it!!!!
Performance is great -- it did bring my GTX 570 down to 15fps when maxed out, but reducing AA from Extreme to High fixed that and gave me a steady 40fps. Turning off ambient occlusion put me up in the 70 to 100 range. However, at some points when driving at high speed on the freeway, even though the FRAPS framerate counter remained firmly in the high 30s the picture appeared to chug and stutter for a few seconds. Not sure what that was about, but it was annoying.
hit Q for advanced options you can disable that
