Hmmm...
This one has bugged the hell out of me, and there must bne a simple reason, but Im lost?
I have rebuild my Server, ready to turn it into an actual server rather than a very expensive WinAmp player.
I have built a unit for it, and I am using a KVM with super massive long VGA and USB Cables to control it. Everything is working as it should be, however, I just cannot for the life of me, get teh server to access the internet?
When I view the NETWORK through the Server, I can see and full access both my main Desktop PC, and my daughters PC, and I can see the Netgear router.
The Netgear router, is a full modem router, however, I an only using that for getting the Media PC, the Skybox, and the XBOX onto the network, and I am NOT using the WAN or the Modem ports, just the 4 Ethernet ports so its acting lik a 4 port switch right now. It works 100% fine for those devices.
My main Router is an ASUS 55 thingy ( GET NAME )
The Main Router is at 192.168.1.0
The Netgear is at 192.168.1.1 and is NOT assigning IPs
And the entire network works exactly as it is supposed to, with all the machines all seeing each other and having full access to the internet as I want them to.
Now, the server has 3 Ethernet ports and I have also plopped in a Wireless PCIE card into it.
One port is the LAN Diagnostics thingy, and of the other 2, I have disabled one for now, and I am only using PORT 1
Now, on the ASUS, its WIRELESS networks are called LAN-AUTO ( the 2.4Ghz one ) & LAN-05 ( The 5Ghz one ).
One thing that I have noticed that the Ethernet is seeing, and this is a really weird one, but it sees the network and sort of connects to it, and calls the network LAN-AUTO and yet thats the name of the WIFI LAN not an ethernet one? Why is that?
I just cannot get it to connect to the internet, and it can only see 2 machines so why is that?
Anyone have any ideas, or need to know any specific info?
I have also done a fresh install just on the off-chance and this made no difference!
