only using 4pin atx connector on 8pin board
17 Jul 2008
SHould this work?
I thought I have done this before but I get a CPU init error a asus striker extreme.
I am not 100% sure the board is ok, so I don't want to order a new PSU if it should work with the 4 pin connector
I have tried different CPU and memory
any ideas
thanks
Should work fine but it will affect overclocking. Most 8pin boards come with a cover over the bottom 4 pins, What cpu are you running?
e6600 also tried a celeron something (core), I tried resetting the bios for both cpu changes..
I assume its borked then?
Think so i have a q8300 stock clocks with 4 pins (limited by mobo) and it works fine. The only cpu i could see having problems are the core i7 6 cores.
