So i just changed my motherboard yesterday, i was just putting the clips back into the base frame of a Arctic freezer pro 7 and managed to completely snap it!
Gutted, so as i needed my pc i put a little super glue on it and put the cooler in it's place as normal.
Do you think it will hold securely or am better off buying a new cooler. It seems quite secure, but i'm not sure how super glue is on plastic to plastic.
Any recommendations for a cooler that doesn't cost the earth, and will fit in a Lian-li pc c33b case (no taller or wider than the freezer pro as it only just fits)
Cheers, Rich.
Cheers, Rich.
