Open dialogue shortcut folders help
18 Oct 2002
Im am trying edit the folders that appear down the side of a Open or Save dialogue box.
I found several sites saying to find the registry entry Opendlg32 and edit that.
I could not find this in my registry but successfully created the Key and added strings of the folder locations and everything worked fine.
However when I enter My computer as a string it creates a folder with no access to anything (it just does nothing)
I can use Desktop and it automatically assumes its the desktop, but my computer doesn't work.
Does anyone know if My Computer has a specific location or is a specific program that I can locate to?
(If i rename the comdlg32 key the original shortcuts reappear including my computer)
There was no original key, oddly. I had to create the key for comdlg32, and add the strings myself, which did the job, and if I remove it they return to there original folders.
I just can't add My computer as a shortcut.
