open ofice
18 Mar 2009
i am getting my old pc ready for work and i need a ofice aplication for it. it has xp home. 2.8 ghz single core processor and >1gb ram. im tuck between putting office 2007/8 or open office on. i dont think it will be powerful enough to run office. how system heavy is open office? and can you open/make files that work with word as i will probaby transfer files over. thanks
Office is hardly a system hog.
In answer to your second question, Open Office will open .doc files fine :)
Office should run no problem to be honest. Sure it may be a little slow to Open but once opened then it shouldn't require much system resources.
Open Office can save in the standard .doc format I think. Not too sure about .docx since I haven't used Open Office in around 5 years
I prefer Office although that is most likely down to just being used to using it.
When I used Open Office is just looked plain and dull and the formatting wasn't great. Although that was 5 years ago and I am sure they have improved it by now
Office 2007 runs fine on a 1.6 Ghz atom so it won't have much trouble with your system.
I found the formatting options in Open office to be terrible. Bullets and tabs never really worked the same, and often messed up formatting from word documents.
I have Office 2007 and Open Office. If you just want to fire out the odd document Open Office is great. If you spend a lot of time word processing, formatting and have to deal with other people's Word documents and macros all the time then there is no substitute for MS Office.
i prefer open office 3.06 to Office 07
if i had to pay £200 for Office 07 or Open Office
id buy Open Office without a doubt it looks neater, linux style icons if it crashes it recovers 100% of data lost. office 07 still struggles at work.
only down side of openoffice its slower load up time to start with.
its a shame its written in java but also a plus.
C/C++ would been faster for Win
But Java makes easy to do cross-platform :D
I'm a big fan of openoffice! I have Office 2007 Ultimate as well and it just feels slower (to load up). I also HATE the new layout. Can't find things for the life of me!
My work also involves a lot of heavy mathematical notation and I find that MS Word's equation system (although o.k) is not very convenient and can be very hectic. The formula input in OO Writer is far more convenient. And yeah I know I should be using LaTeX this kinda stuff, but I cant be bothered.
Mind you MS Office only cost me £40 so I can't really complain
