Open Ports and Port Forwarding
3 Jan 2009
I'm using the Network Utility to check which ports are open. How long should this take? I've been running it for about 10 minutes now and it's still going. Is that normal?
Are you trying to verify your own port forwarding setup? That port scan utility scans a remote host.
If you want to check yourself, make sure to open the application(s) that want to listen for connections and try something like this with each port in question: http://canyouseeme.org/
