this is my idea for the core parts of my ring the parts below are all i need but am after some other people to have a look and see if it should be tweaked a bit in any way am open to ideas but if you do change anything please give a reason for it as it will help me decide what s do the two fans i have selected must stay as the rest of the fans i have are the same
pc will be used for gamming vid and music encoding and 3d modeling
kind regards
Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail
£249.9
Asus P8Z77-V DELUXE Intel Z77 (Socket 1155) DDR3 Motherboard
£194.99
Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2)
£107.99
Samsung Green 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit (MV-3V4G3D/US) x2 16g
£83.98
Be Quiet Shadow Rock Top Flow CPU Cooler (Socket Intel: LGA 775/1155/1156/1366/AMD:AM2/AM2+/AM3/754/939/940/FM1)
£37.99
Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin x 2
£31.96
kind regards
£249.9
£194.99
£107.99
£83.98
£37.99
£31.96
