OpenCV android Project
17 Dec 2015
I am working on a machine learning project, using, opencv, android studios platform. it incorporates a image pre-processing stage and a machine learning stage. For the pre-processing stage, the use of Gabor filter, adaptive thresholding, sobel edge detection, and blob detection were employed. then followed by the machine learning stage (SVM). Video frames are loaded from a saved file and fed through the pre-processing pipeline. the stages involves the use of OpenCv libraries, I am currently working on a sample code for the pre-processing stage but I have Issues with any line of code that has "(R.id.ivImage)" R dot id, I believe it has something to do with my xml file but I cant figure it out.
I will like to know if anyone can help streamline the project and correct or add relevant features
This has nothing to do with opencv or machine learning but android. If it was the former I could help but I don't know the latter.
