openoffice/excel % advice
Suspended
17 Mar 2004
Market Drayton, Salop
hi all,
Just a quickie.
I have the following:
column A = Product name
Column B = Item Code
Column C = Standard Price
Column D = Discount
I am trying to work out the cost of a unit with the discount applied but cant figure it out. So in column D i want Standard Price minus Discount = new value.
Can this be done ot will i have to work out what a 5% discount is of the std price in column E and then subtract E from C??
Normally i check my books but i lent them out to a friend! :(
You will have to go for the second option, otherwise Excel will complain about cyclical references.
This should do it (Example formula is for the standard price in cell C2)-
Code:
=(C2*0.95)
You'll also need to set the cell type to currency to make the rounding work properly.
I don't see where cyclical references come into it, all you want is 95% of the price in column C.
Unless I've missed something? :confused:
-Leezer-
Sorry, I think I misunderstood the question. I initially read that the % discount would be in column D (and might vary from 5%) and wanted the end figure also in column D.
