I have a typical y-plan heating setup with hot water cylinder, 3-port valve, and pump. My boiler is being replaced with an Ideal Logic+ 15 Heat controlled by an existing Tado Extension Kit / Smart Thermostat. This is currently connected using the 230V on/off method.
The Logic+ has OpenTherm connections and was wondering if this can work with a y-plan setup. Any heating geeks in here that have done something similar?
