Hi,
I'm having some problems getting an openvpn server/client to route/work correctly.
The network looks like this:
Network 1 (VPN Server on 192.168.1.45):
Many hosts (192.168.1.x) -> ADSL Router -> Interwebs
Network 2 (VPN Client on 192.168.1.30):
Many Hosts: (192.168.1.x) -> ADSL Router -> Interwebs
So everything connects and authenticates fine, and both networks have a virtual Ethernet tap device created at 192.168.1.80 (defined in my server.conf). There's no obvious errors in the logs and kernel ip forwarding is enabled at both ends.
So I'm all connected with a working? tap device, from here I assumed I would be able ping hosts between networks, i.e 192.168.1.10 on network 2 should be able to ping 192.168.1.47 on network 1.
My routing table looks like this on the client:
The client's tap0:
So, any 192.168.1.x packets first go out on the local LAN, if that fails they should get routed to the tap0 interface and get VPN'ned right? And failing that we go to the gateway.
However none of the hosts can speak between networks. Am I doing something obviously stupid here? Or is there more complexity required in the routing tables?
EDIT: The server is using a bridged interface, but also has tap0 defined. Not too sure if this is correct or not? So I think br0 is bridged with the servers eth0 (lan network).
Code:
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 * 255.255.255.0 U 0 0 0 eth0
192.168.1.0 * 255.255.255.0 U 0 0 0 tap0
default dsldevice.lan 0.0.0.0 UG 0 0 0 eth0
The client's tap0:
Code:
tap0 Link encap:Ethernet HWaddr EA:7B:63:5C:82:23
inet addr:192.168.1.80 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::e87b:63ff:fe5c:8223/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1238 errors:0 dropped:0 overruns:0 frame:0
TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:77652 (75.8 Kb) TX bytes:468 (468.0 b)
Code:
Routing table (server):
192.168.1.0 * 255.255.255.0 U 0 0 0 br0
default bebox.config 0.0.0.0 UG 0 0 0 br0
