Open source router firmware OpenWrt ships its own hardware
'Forever unbrickable' Wi-Fi 6 box from Banana Pi comes packaged or in kit form
It will be interesting to see what the reviews are like being just dual core.
Maybe take a look at the Gl.Inet MT6000 quad core running a (lightly skinned) OpenWrt. I think you can wipe it and put vanilla OpenWrt instead if needed.As the OP said cpu, would have been perfect for a Plex Server with MVMe onboard and faster quad core cpu, or anything usefull ie container or even VPN. Yeah lets hope they get a grip of it. Maybe people are too snobbish and want everything built in these days. I guess PoE makes sense with the dual core only cpu to keep the power feed low.
I've no interest in OpenWrt any more, I use Mikrotik now. So If I wanted that capability the RB5009 would be my choice.Maybe take a look at the Gl.Inet MT6000 quad core running a (lightly skinned) OpenWrt. I think you can wipe it and put vanilla OpenWrt instead if needed.
First thing I saw and thought what a waste.I am not sure why you’d set out to build a device for enthusiasts and put one 1Gbps and one 2.5Gbps interface on it.
Which hardware is this ?I hope this doesn't give people a really bad impression of OpenWRT due to the port stuff. It is really bizarre and when this was announced months ago people had the same statements.
Really one of the best free software imo but the price is also pretty high for this. If you know what you're doing you can get Wifi 6 AX6000, a much better CPU (2 Ghz MT7986A), 2 x 2.5 Gbps ports and 4 Gigabit ports that will run openWRT for under £50.
Zyxel EX5601Which hardware is this ?
A security issue was reported to the OpenWrt project this week around their Attendedsysupgrade Server (ASU) instances that could have led to compromised firmware images being served.
The good news is that it's believed no official images from downloads.openwrt.org were affected nor any custom images from the 21.10.0-rc2 release. OpenWrt developers were only able to verify the build logs for the past seven days due to automatic clean-up of older build logs. Users are thus encouraged to carry out in-place upgrades to the same version to eliminate any possibility of being affected.
Hopefully end of year for the 2: https://lists.openwrt.org/pipermail/openwrt-devel/2025-February/043722.htmlNo need for this.
Should have decent and fast hardware running your primary gateway
openwrt primary running as a proxmox VM (5700u mini pc with bonded 2.5gbps usb network adapters)
openwrt secondary failover running on hardware (Linksys E8450 (UBI))
Thanks for the heads up ... I'm looking at upgrading my secondaryHopefully end of year for the 2: https://lists.openwrt.org/pipermail/openwrt-devel/2025-February/043722.html
The One is pretty underwhelming and the Two is kinda overkill but if I can get this for under £200 I'll bite. The Wifi 7 drivers should be pretty good come October/November release.
