Opera 9 TP2 Released
26 Dec 2003
London
Technology Preview 2 of Opera 9 has been released, and there's lots of bugfixes and improvements over TP1, and zillions over 8.x.
Changes Since Opera 9.0 Technology Preview 1
User Interface
New Opera Widgets feature. Widgets are small Web applications that live outside the Opera window. Press F6 to enter widgets mode. See the widgets tutorials for more details.
Added content blocking feature. Right click on a page and select "Block content", then click on content that you want to block. Alternatively, use Tools > Advanced > Content blocked to manage blocked content.
Added search shortcut editor. Right click on a form input to add it as a search shortcut, or use Preferences > Search to manage search shortcuts
Enabled support for BitTorrent.
New search shortcut 'b' searches BitTorrent
Added site specific preferences user interface.
Press F12 and choose Site preferences to set preferences for the current site, or use Preferences > Advanced > Sites to manage site specific preferences.
Preferences that can be set on a per-site basis can now be accessed using Preferences > Advanced > Sites > Default settings.
Web page thumbnails are now shown when hovering tabs.
Thumbnails are also available when switching tabs using Ctrl+Tab. These are disabled by default but can be enabled using the [User Prefs] Use Thumbnails in Window Cycle setting in opera:config.
Added grouping by date and site to the History panel.
Added syntax highlighting to source viewer.
CSS errors are now reported to the message console.
Tabbed browsing mode now opens a new tab if all existing tabs are closed.
Local stylesheets can now be specified as a directory using the [User Prefs] Local CSS Files Directory setting, and all stylesheets in that directory will be used to populate the on-demand user stylesheet menu.
New styles for opera:about, opera:cache, opera:config, opera:error, opera:history, operalugins, file: view, and Info panel.
opera:config says what changes were saved.
opera:config now allows linking to individual preferences, and searching within headers.
Simplified bookmarks and Wand dialogs.
Added keyboard shortcut Ctrl+Enter to auto complete¨"www" and "com" when used in the address field.
Ctrl+B can be used instead of Ctrl+Shift+V for paste-and-go.
Messaging and Newsfeeds
New e-mail header toolbar.
Improved IMAP folder synchronisation.
Improved moving of email between IMAP folders.
Fix for duplicates showing in IMAP sent view.
Fix for messages showing blank
Added support for importing and exporting feed lists in OPML format, using File > Import and export.
Default mail views can no longer be renamed through the mail interface. They can be renamed using language packs.
Added a warning when sending mail without a subject.
User stylesheets are no longer applied to mail, news, and chat.
Added smiley menu to chat and mail toolbars.
Added CTCP flood protection to IRC chat.
Display
Added support for CSS 3 opacity.
Media queries now understand several CSS length units, and can check additional media features.
CSS rules that are only partially correct (for example, '1px solid notrecognised') are now ignored.
Printing now uses backgrounds from print media instead of screen.
Text-decoration is retained on absolutely positioned links.
Attribute selectors now use the specified value of URIs, instead of resolved values.
Button elements now respect display:none.
Multiple fixes for styling of legends and fieldsets.
Allowed coloring of text and backgrounds in option and optgroup elements.
Fixed a regression with CSS attribute selectors failing to understand percentages.
Improved handling of tables in ERA.
Improvements for BIDI, including handling of padding-right, align="justify", and alignment in ERA.
Improved handling of vertical-align.
Improved handling of CSS 3 UI element states pseudo-classes.
The align attribute will now apply to TR, TBODY, THEAD and TFOOT as well. Block-alignment will not be inherited from table or inline-table.
@import is now supported in user stylesheets.
Fixed handling of alternate stylesheets in XML.
Added support for -o-text-overflow:ellipsis, synonymous to text-overflow:ellipsis in the current CSS 3 working draft.
Updated display:inline handling on tables according to upcoming CSS2.1 specification update.
Changes to defaults
Anonymous table cells in a display:table; now have a default vertical-align:middle;
Form default margin-top is now 0, and margin-bottom now 1em.
Several changes to the default margin and padding of legends and fieldsets.
Script
getAttribute and related methods now retrieve the specified value of URIs, instead of resolved values.
Improved DOM error reporting.
Multiple fixes for XPath and XSLT.
Fix to prevent reprocessing of scripts when a script element is moved through DOM.
Enabled getElementById to retrieve elements based on attributes set to the ID type, by the DTD.
Improved handling of the load event when navigating back and forward through history. See the knowledge base article for more details.
Improved redrawing of table rows when dynamically changing styles.
Added Node.text property, equivalent to Node.textContent
Added support for the Element.currentStyle property.
Canvas:
Fix for rect() and fill().
Added support for standard CSS color styles such as rgb() and color keywords.
Improved handing of resizing the canvas.
display:none on images in HTML no longer causes those images to fail to draw in canvas.
Many path() fixes.
Forms
Fix for selecting text with different sized fonts in rich text editing.
Added support for inserthtml, contentreadonly, increasefontsize, and decreasefontsize in rich text editing.
Rich text editing now allows selection of images.
XHTML forms are no longer submitted if they do not have an action attribute.
Added support for the datetime input type.
Fix to allow inputs to have a large maxlength value.
Improved keyboard accessibility of Web Forms inputs.
Enabled the htmlTemplate property.
Added support for the datalist element and list attribute.
Added support for Web Forms 2.0 step="any".
Added support for oninput and onforminput events.
Removed support for maxlength on file inputs (this section of Web Forms 2.0 has also been changed).
Added support for Web Forms 2.0 repetition.
Images
Added support for YCCK and CMYK formats in JPEG images.
Multiple improvements to SVG 1.1 basic and SVG DOM support.
Plug-ins
Initial implementation of NPP_GetValue().
Re-enabled scripting of plug-ins with Java using LiveConnect.
Security
Security bar is now greyed for sites using an encrypted connection, that have a low security rating.
Updated expired TrustCenter root certificates.
Fixed a TLS Extensions format error.
Miscellaneous
Rewrote server push handling.
Fixed handling of target="_top" and target="_parent".
Removed support for the Content-Location HTTP header as a base HREF.
Site patching can now download certain site specific preferences as well as Browser JavaScript and user agent overrides.
Multiple stability fixes.
Windows-specific changes
Added experimental support for NTLM authentication.
Fix for importing Internet Explorer favorites.
When first run, Opera will attempt to import bookmarks from the default browser. Internet Explorer, Firefox, and Opera are supported.
Known issues with widgets on Windows 95, 98, ME and NT:
Widgets may fail to render correctly.
Download away!
Conrad11 said:
I got one of the codes during the give away, if I upgrade will i lose my add free version?
Not long after they gave out all the free codes they made it ad-free :p
Just downloaded the new version and can't see much difference at face-value. I was interested in how they'd handle the previously rumoured bittorrent implementation, but it's nothing to write home about really!
i`m well impressed with opera so far. everyhting displays well, sometimes better than Firefox, its more inline with IE, kinda in between IE and firefox. Middleground, which is nice.
Generally speaking (99.9% of the time), if a website doesn't render properly in Firefox it's the fault of the website, not the browser. Internet Explorer has a number of quirks (Most notably it's totally off-the-wall interpretation of the box model), and in that respect it renders websites incorrectly (or atleast, according to the World Wide Web Consortium's standards). I have no idea what rendering engine Opera uses, but it usually follows Internet Explorer's conventions, and thus is a pain for people who develop websites according to standards.
Certainly a good browser though. Was very pleased to see them remove the ads, and they seem to be working on the browser at a nice pace :)
