Operton 146 Overclocking
22 Oct 2006
Hi just joined!
Last week I bought an Operton 146 CAB2E 0602, does anyone know if this is a "dog". I'm having trouble overclocking, it will not go over 2.3!
I'm not looking for a vast increase but at least 2.6 which is not unreasonable.
any idea's or is this going to ebay!
A'hoy there :)
Had my Opteron running at 3.0GHz fairly easily, so I'm sure you can get that running at least 2.6-2.8GHz unless it's a poor chip.
What motherboard, ram and cooling do you have for a start?
Hi DUKE
Motherboard is an A8N-SLI SE on air, 4 x 256 corair value 3-3-3-8-2T
I suspect it a bad chip, ok the memory is not great but it will not be holding it back that much
Try running the RAM on a divider.FYI the ram IS probably exactly what is stopping it.
Ok Thanks
Changed memory to 333 and is now running at 2.7, so now I will play a bit more! If any one has one of these ( 0602) what did you get it to?
thats a great stepping imo... mines the same stepping, just google it most seem to be going 3ghz easy, i know mine does :D , only problem i have with mine is bad contact/concave ihs so 1.5v = 57-60c load.
so i run with 1.4v and still get 2.9ghz.
