Opinion On Spec
30 Dec 2012
Derby, UK
Would this spec be ok for a friend of mine?
Core i5 3570k
Gigabyte z77x-d3h
8GB Corsair Vengeance RAM
Sapphire Radeon HD 7950
128GB SSD
2TB HDD
Zalman Z11 PLUS Case
Corsair H60 Water Cooler
XFX Pro Series 650W
Looks okay.
Whats the budget? and what is the use? Gaming?
Are you setting it up for Xfire or not..
If you are, get a XFX XXX 750W PSU
If you are not, Switch the Z77X D3H for the Z77 D3H
The H60 isn't the best. You can get a great air cooler for that money (or a fair bit less).
The choices are pretty good though.
PS: Not a fan of the Z11 myself, the Z9 is more my cup of tea. :)
Looks okay.
What air cooler would you recommend for the same kind of money? And main purpose is for gaming primarily and editing on occasions
Doomedspeed's build looks good, virtually identical to what I have and that works perfectly for gaming and other general usage. I would echo the comment about going for ~750W if going Sli, you could probably get away with 650 but the AMD series are more power hungry so I would play it safe.
