opinions on Coolermaster Mystique 631 Black Aluminum Case??'
It looks a reasonable case with plenty of room. I'm not keen on the styling myself but that's subjective. A quick google threw up some reviews and I couldn't see any blow hole on the pics.
Review here: http://www.bit-tech.net/modding/2006/08/11/coolermaster_mystique_632/1.html
Dont see the point of the doors personally and that orange plastic just looks so 'cheap'.
nick_lerwill said:
or are the older coolermasters betteR?
Better in what sense and when you say old how old?
The ATCS cases are definately better in terms of build quality, cooling is not better at they are limited to 80mm fans (athought they still cool well , modern cases feature 120mm fans) and in my opinion they look much better.
The newer but now old Praetorian (201 style) and the wavemaster are also of good build quality.
Personally i'd go for an old ATCS cooler master case every time
thing is my wavemaster doesnt do cooling. its got 1 effective fan out of the 3
Harib0 said:
Care to explaine more, what do you mean it only has one effective fan?
Right basically theres 2 intakes and 1 outake the holes in the case that 'feed' the fans with air are really small therefore the 2 fans dont do the job anywhere, the case will cool any cpu or single gfx card fine, but dont put quad sli in it
Eliot said:
Right basically theres 2 intakes and 1 outake the holes in the case that 'feed' the fans with air are really small therefore the 2 fans dont do the job anywhere, the case will cool any cpu or single gfx card fine, but dont put quad sli in it[/QUOTE
Ahh thats better, so it does cool an average joe blogs system but not your high end quad sli system.
I've not had the opportunity to inspect a wavemaster in real life, so i can't really comment but there must be somethign you can do to help the air flow on the 2 intakes
I have a ATC 111. The fan placement is just about identical to the Wavemaster (I think it uses the same chassis), with the exception of an additional blowhole on the top. I'm sitting quite cool in undervolted fans with an overclocked dual core Opteron system and 7800 GTX 512 (single not SLI).
I know if I really had to I'd be able to cool pretty much anything in there. It's just a matter of putting the right fans in, probably at the expense of noise though. At a real push then just cut a blowhole in the side and put a 120mm in there.
But a new case is always fun of course :)
no no no, the holes are different, u could put a delta in it and it still would be held back. But with a meaty drill u could make a gap in the holes for better airflow, or u could dremel it all out
I understand now, the 201, 111 has a mesh grill on the front - the wavemaster does not it has a series of holes behind the front raised bit that lights up, this prevents good airflow into the case. Hence a drill being they only way to make the holes bigger
