I am posting here as my project log where I have been posting my progress and ideas has had no feedback to my recent ideas.
I am modding an HAF 932 and would like to create a bottom divider such as the one found in the Corsair 800D. The sketchup should give you a quick idea of what I am aiming to achieve:
I intend to cut some aluminium to cover the PSU up to the HDD bays and put a side on it too. I will cut a fan hole in the top and put a grommet for the front panel connections. It will also cover all the cables of the PSU as they go behind the motherboard tray. I may also make a custom HDD rack to put in the compartment and remove the original 3.25" drive bays to increase airflow.
However, there is a slight problem. When I come to cut the window I have to cut it below the divider due to the fact that I will have to cut around the existing features of the side panel. So although the divider will have a side so you can't see in- you will be looking at a piece of metal along the bottom few inches of the window. I could put some cool stencil text on it but I still think it would look strange. Any ideas on how to make it look better or whether I should do it or not?
