opinions on my latest overclock ?
Permabanned
11 Mar 2004
just got some nice shiney corsair 2X1Gb XMS ram (the first time in my life ive had ram thats actually worth a damn...)
oc`d my cpu some more and set the timings on the ram, heres the results...
opinions and comments welcome, especially suggestions regarding my settings as i really have no clue if what i have done is correct.
p.s. ... i dont think its bad considering im on an Asrock dual SATA2 939 motherboard. :)
My opinion is that your theme is the ugliest UGLIEST thing i have ever seen and honestly i would be surprised if you dont have a vomit bucket on standby every time you boot up.
Sorry.... but LOL :p made me laugh
hey!! i love my theme!
Teknodeamon said:
aztechnology said:
I'm just glad Adblock lets me block image sources :)
Congratulations, your all possibly the most stupid bunch of ******* trolls ive ever seen, ffs if youve got nothing good to post, why be a bunch of idiotic noobs and bother at all, next time try engaging a little intelligence and answering the ******* question, or better yet, leave the forums and come back when youve reached puberty :mad:
your doing it correct, yes :)
time isnt bad, but could be improved...
first thing id do tho is set the ram divider to 1:1 (200mhz) and see how far the ram can go, set HTT to 3x and push up, memtesting each time, keep timings at 2.5-3-3 and then see if you can go further at 3-4-4
and guys, if your gonan joke about his theme, fair enough, but only if you also post something usefull, dont just post that only, thats just spamming :o
if set to 1:1 they would be running at 270fsb, and just dont boot ;) but i get what you mean and will try slacking off to achieve a better result.
p.s. thanks for your comment about the thread, much appreciated.
lmao that's a awesome post. Made me laugh :)
But on a serious note back on topic, is that the maximum stable speed you get? Or does it crash after a period of time? (is it stable for normal usage?)
I have had really high speed clocks which lasted through a pie test, and die a few mins after it....last thing you want is your comp crashing in a middle of somthing important.
i mean back off to 200 again, and up slowly at 1:1 ... to try and find the maximum, it may be less than 270... but you wont know what it is till you try :)
i cant run my ddr and cpu frequencys seperatly, if i back off the ram and set to 1:1 it tops out at 262 which means my cpu is not clocked as high as it was, hence i run on a divider :(
