opinions on silverstone sugu and x-qpack
12 Mar 2005
stoke on trent
thinking about building a small one any body got one of these cases and what are your opinions on them
personally i think the sugo looks a lot nicer, and has got some good reviews from what ive read. though i havnt read any on the x-qpack so could be equally as good if not better. people on here seem to like the x-qpack judging from all the posts on them recently :)
I have had both, and a couple of Biostars, and an ASUS Vintage PH-1 and I've built at least 3 shuttles and I would say that if you are looking to spend good money on something you want to last, buy the Sugo. They are both quite cramped inside though and if you use a full-size PSU then the optical drive length becomes critical.
Shuttles and the like come up quite regularly on Member's Market. Post sensibly, but often, get youself in there and see if you can't get a proper bargain.
And I still say that the ASUS you were looking at is a perfectly adequate piece of kit.
Yeah the Q-pack is an ok case for the money, although there are some issues with it, as cokecan said there is a lot of info on this case on the threads here check them out.
