Shopping Cart (Prices in British Pounds)
REFERENCE DESCRIPTION QUANTITY PRICE COST REMOVE
CP-118-AM AMD Athlon 64 3200+ Venice 90nm (Socket 939) - Retail (ADA3200BPBOX) (CP-118-AM)
£95.95 £95.95
MB-119-AS Asus A8N-VM CSM Micro ATX (Socket 939) PCI Express Motherboard (MB-119-AS)
£54.95 £54.95
MY-004-OK OcUK Value 1GB (2x512MB) PC3200 184pin DDR Memory Dual Channel Kit (MY-004-OK)
£39.95 £39.95
HD-023-SA Samsung SpinPoint P HD080HJ 80GB SATA-II 8MB Cache - OEM (HD-023-SA)
£34.95 £34.95
CD-020-SO Sony DDU-1615 DVD-ROM (Black) - OEM (CD-020-SO)
£10.95 £10.95
CA-001-OP Optronix Midi Tower Case Bundle Kit (Keyboard, Mouse & Speakers included) - Black/Silver 400w PSU (CA-001-OP)
£29.95 £29.95
CA-026-EN Enermax Liberty 400W ELT400AWT ATX2.2 Modular SLI Compliant PSU (CA-026-EN)
£44.95 £44.95
Subtotal £311.65
VAT £54.54
Total £366.19
Hi,
Could I have some opinions on the above spec please? It will be used for office work, internet etc but no gaming. It must be easily upgradable though which is why I have gone for a decent parts (Not that bothered about the case although I did build a system with it the other week and was very impressed with the build quality and the cooling on it
). I don't want people saying 'Oh, that's soooooo overkill, that could all be done by a Socket A sempron' so if you have only those comments to make, please refrain from posting
Budget can't go any higher- this is all they have as they've already bought a 19" LCD monitor and a DVD-RW.
Thanks for any opinions/improvements
Ben
£95.95 £95.95
£54.95 £54.95
£39.95 £39.95
£34.95 £34.95
£10.95 £10.95
£29.95 £29.95
£44.95 £44.95
Subtotal £311.65
VAT £54.54
Total £366.19
Hi,
Budget can't go any higher- this is all they have as they've already bought a 19" LCD monitor and a DVD-RW.Thanks for any opinions/improvements
Ben
It came with 2 x 80mm fans but they don't seem to shift much air. Taking the case covers lowers the temps by 3 degrees but I can't leave it without the covers on if you see what I mean. Should I just put up with them then? I'm perfectly happy with it as long as it doesn't blow up or melt lol
