Opinions on the OcUK Rainbow Case?
Man of Honour
25 Oct 2002
Hampshire
I am contemplating putting together a second system from the odds and sods I have lying about, but I need an ATX case to put it in. Does anyone have any experience the Rainbow cases from OcUK (or indeed the Optronix one?)
I won't be expecting brilliant for the money, as I'm not looking to spend a lot on a secondary PC. System would probably consist of:
Abit BD7-II
P4 1.8a @ 2.7ghz
2*512meg DDR400
Voodoo3 3000 PCI
Pioneer DVD-RW
HD of some description (possibly on a PCI SATA controller)
As it's a secondary system, it's unlikely I would want more than a couple of HDs in there, and not many expansion cards either. Basically I just need to know what the build quality is like, if it comes with a bunch of screws etc, and if everything fits in properly.
Here's the inside of mine although I didn't buy it from OCUK as it came with a prebuilt Athlon XP system and it isn't badged as a rainbow.
It's not great in terms of cooling but what do you expect for 20 bucks. :)
Must admit though it will be going in the bin shortly when I get my watercooling system.
Edit: The PSU isn't the one that comes with the case.
You get what you pay for... they will not be very high quality and as you cans ee look naff.
The optronix doesnt look bad though for £26, certainly worth the extra few quid.
^inside of the optronix... PSU seems to be much better than the rainbow one though
Spend a little bit more if I were you and get yourself something like a CM 530 or Antec Sonata II (with PSU). Ok, much more expensive than a junk Rainbow case - but they will both have a re-sale value that will mean you lose nothing on them, unlike the Rainbow. They'll look ablot better too and the bandages can stay in the cupboard.
If I was building a primary system then yes, I wouldn't be looking at a case under £50. However as I'm thinking of just building a second rig from bits as a bit of a sideproject, I'm not looking to throw too much money at it.
The re-sale value of a case isn't such a big deal to me - due to the high shipping cost involved there is little benefit in me trying to sell cases, and the kind of people who are likely to buy it as a whole system probably wouldn't give a damn what brand of case it has anyway :)
I do have a spare PSU kicking about, so buying a case without a PSU would be a possibility if the price is right. I see Antec have one at £32inc, which is just about within my budget I suppose if it is high quality.
edit: thanks for the pix.... Optronix looks like it has a decent number of 3.5" bays, which is always good (can't fit more than 4 hds in my Chieftec Dragon due to the power molexes on my gfx card getting in the way)
