Thermaltake Site Link
I've been toying with the idea of getting a new case for a while now, also been thinking of watercooling my E6400, but have never watercooled before. First I thought experiment with a cheap kit on my second rig, then I was told that'd be a waste of money, just get a swiftech ultra kit and i wont look back. Now that idea is fine, i'm sure it's a very good kit, but problem is there's no room in my current case for any watercooling equipment.
My mate has a TT Kandalf case and it's very impressive, and very heavy!! I like the way there's lots of room inside the case and plenty of fans for air circulation.
Thing is, that case is £120+del which is a lot for a case, although probably worth it.
That's when I saw the TT Kandalf LCS-VD4000BWS. It's the same case (i think) but has all the watercooling stuff you need to start your own water cooled PC. A 380MM radiator cooled by 3x120mm fans, a 500L/hr pump, 350cc reservoir, copper water block and tubing. All for only £164+del surely that's a good deal. hell even if the TT water cooling stuff is rubbish, ie the pump and block, the radiator is surely as good as any.
If i can find out when the case is back in stock i might just order one.
Any comments on the case would be appreciated.
