Opportunity to get a D3100..
  • Thread starter Thread starter 4p
  • Start date Start date
4p
4p
20 Jun 2006
Capital of The North
For £300, inc the VR lens. May as well. Brand new.
Really need a 300mm lens for wildlife shooting though, can anybody recommend one outside of Nikon (quite expensive :D) ?
It's the D3100 :)
Well in Currys the Nikon 70-300mm was around £350 :o
I heard Tamron can work with Nikon?
Tarmon generally have a slightly sluggish AutoFocus so maybe not ideal for wildlife. Sigma do a 70-300mm 5.6 but its not as good as the Nikkor though chances are unless you're a pixel peeper then you won't notice too much difference.
Tamron AF 70-300mm F4-5.6 Di LD Macro 1:2 Nikon+Motor
£99.95
que?
Nikon AF-S VR 70-300 f/4.5-5.6G IF-ED
£342.34
That the lens i should be looking at? The camera is actually £220, so spending so much on a 300mm seems a little bit easier now :p
It's the D3100 :)
Have a look at the Nikon 55-300 DX VR. It is almost as good as the Nikon 70-300VR but made much cheaper and only covers crops sensors. Goes for 236GBP online.
The Tamron 70-300 VC is very good but not miuch cheaper than the Nikon 70-300 VR.
Both Sigma and Tamron make cheaper 70-300 lenses but their performance isn-t great. I had a Sigma 70-300 APO as a begginer lens on a 6MP Nikon D70. It was OK but was really too soft at 300mm even when stopped down and the focus was very slow. With a 12MP and more sensors I think the value of these cheap 70-300 lens is not really apparent.
I can say that the Nikon 70-300 VR gives professional performance up to 220mm or so, and very good to 300mm if you can stop down a little.
I don't mean to hijack or anything but what does 'stop down a little' mean? I a noob you see :)
Stopping down means going a few F-Stops down from Wide open. e.g. a f5.6 lens will have a sweet spot at about f8.
At least how I understand it :P
...beaten to it.
£99.95
que?
Its terrible, really terrible.
The more expensive APO is at least usable, the non APO version .. stay well away
It is not good at all, even as a beginner with a D3100 I could spot that. I bought one and took it back two days later (took a day before I could test it properly at the 20:20 cricket) Auto focus would hunt really badly a lot and it got quite soft at the longer end of the focal range. I took it back and then bought a 55-200 Nikor which although shorter, I find a lot better and will do for now as it only cost £150 with AF-S and VR.
