Opteron 146 and ASUS A8N-E
7 Oct 2005
Ive decided to get an opteron 146 and was wondering if I can use it in my current motherboard (ASUS A8N-E) or if i will need to purchase a new one, and if so, which do you recommend.
Cheers.
ps. What air cooler would you recommend for this cpu?
However I'm not too sure how good the A8N-E is for ocing, something you should consider, but If you already have it you might as well try the opty in there and see how far it will go
