Opteron 146 - heatsink & AGP motherboard recommendations
25 Jan 2006
I have just got a Opteron 146 CABYE 0540 FPMW, and I'm looking for a motherboard and heatsink, the only problem is that I cannot afford to switch to PCI-E as I really want a Silverstone TJ07 so it would have to be AGP.
I have seen the Thermaltake Big Typhoon mentioned as a good option for air cooling - I can't afford water cooling or phase change yet.
Also any recommendation for a reasonably priced PSU.
I am upgrading from a barebones so the only components I am keeping is my memory and hard drive.
Hi,
looks like a nice stepping Opteron you have there! :) anyway I am also using a 146. I have an ASUS A8N-SLI Premium motherboard and a Thermalright SI-120 HSF fitted with an AKASA Amber 120mm.
The motherboard is great and the heatsink is *very* good!
[edit] I don't understand why the Silverstone case is forcing you to use an AGP card?
If I buy the TJ07 I wont be able to afford a PCI-E graphics card as well as the motherboard as it is around £225 + I need a PSU and Heatsink.
How much do you have to spend overall for the motherboard and graphics. I'm pretty sure we could work something out so that you'll get a PCI-E motherboard.
I currently have a Gainward GeForce 6600GT 256MB "Ultra/1980", which is OK for now as I don't have a decent monitor. I also have a ASROCK Combo board that I bought before the Opteron as I was going to keep my 754 3400+.
I suppose I could just swap to the PCI-E version and change the motherboard - this would give me more money to buy a motherboard. I haven't really figured out a budget yet, I want something to get the best out of the Opteron.
I will post what I can spend later when I have figured it out - I have to go to work now.
hi,
have a look at the asrock dual sata2, decentish price and will do a decent job til u can afford a pci-e gfx card.
using one at the mo with a bios flash and my 146 is running at 290x9 on 1.45v.
