Opteron 146 - how to enable PowerNow!?
Caporegime
17 Feb 2006
Cornwall
Have installed cpu driver from AMD's site. Dev Manager reports "AMD Processor Model Unknown", using AmdK8.sys version 1.2.3 as the driver.
powercfg.exe /query reports: "Processor Throttling Not Supported" (using Minimal Power Management in Power Options).
According to this link the Opteron 146 should have PowerNow! available.
Cool'n'Quiet is enabled in the bios (mobo= Asus A8N-E).
Not sure exactly where I'm going wrong.
PowerNow! is what AMD calls the power saving on Opterons as well. It's probably the same as Cool'n'Quiet, just with a more enterprise friendly name :p
I've verified in CPU-Z that the frequency stays fixed at 2500MHz. It is not using PowerNow! else it would step down to 800 MHz.
Wonder if it's because the mobo can't detect the CPU (AMD Processor Model Unknown).
