555BUK said:Both will do about the same speeds with your mobo so go for the 165. The 170 is only benificial if the motherbaord it is used in cannot handle high fsb's.
I have exactly the same chip/steeping and run 2.9Ghz at stock volts. As said above, stepping is more important than chip version, and never know the stepping before you buy. So, if you are taking a gamble, go for the lowest cost option.joeyjojo said:Any 06xx 165 basically. My 0615 EPMW is at 3.06 with 1.525
